Raptor 11:1 stage 2 hotcam problems
Old Dec 5, 2003 | 09:22 PM
AustinONeal's Avatar
Default Raptor 11:1 stage 2 hotcam problems
Im wondering if i bump up the compression to 11:1 and get the stage 2 cam will i have problems with it tearing up my dad has been teling me if i do it with the piston and cam then it going to start tearing up and things are going to start to f up
so i was wanting to know if anyone has had any trouble with a similar setup thanks
Old Dec 5, 2003 | 09:35 PM
raptor03's Avatar
not nesscarily but you have to maintain her a little more and dont get lazy on things,
Old Dec 6, 2003 | 12:59 AM
BigScary's Avatar
right..........
you will just have to make sure that everything is done properly
the oil is changed regularly
and the jetting is not lean.........
Old Dec 6, 2003 | 01:23 AM
geologist's Avatar
I did a 11:1 piston w/ stage two cam and the only problem I have is the starter won't crank it over everytime. I run 50/50 race gas and it loves it.
Old Dec 6, 2003 | 01:27 AM
UBETRUN's Avatar
You should set aside some money for a better clutch. Other than that, keep a close eye on the jetting so you spare the rod and piston unnecessary abuse.
Old Dec 6, 2003 | 06:15 PM
Chimmer's Avatar
I would stick with the stage I cam when using an 11:1 piston. The stage II requires hd valve springs, more freq valve lash adjustments, & a close eye on everything else already mentioned. Try the 11:1 with stage I cam, maybe try some head porting in the future as well. Then in a year or two if you are bored with the power, try the stage II cam & hd spings. Don't forget, the power is mostly top end with the stage II cam. The stage I gives a better mid power hit, more useable for most trail riders. If you are determined to use the stage II cam, I would also use a 12:1 piston to assure a good bottom end.
JMO. Check out my dyno graphs for what the stage I can do for you.
Old Dec 6, 2003 | 06:24 PM
Mr45auto's Avatar
Just for an FYI I also have a dyno chart posted. Mine is with a 686 stage 2 cam. It's gonna be different with the larger bore and FCRs but you can get some idea of where the stage 2 makes power. Mine's also an 01 still running the stock transmission and the only tearing up I do is eating clutches. You can expect to go through a couple every now and then with a higher powered engine.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
