Can I put Paddles on a Wolverine?
Old 12-06-2003 | 11:14 PM
GLWBEAR's Avatar
Default Can I put Paddles on a Wolverine?
Why can't I put rear Paddle tires on my Wolverine? If all the tires are say 23 inch tires why can't I put paddles on the rear wheels? Should I go with 8 or 10 paddles? any suggestions? Skat Trak makes a 23 inch paddle tire which is the same size as the front in diameter. Then why won't it work?
What should I use for the front tires? Use stock or go to something else? Has any body done this before for strickly running in the SAND?
Wouldn't this make the Wolverine better in the sand?
I'm currious if this has been done before and how did it work?[img]i/expressions/face-icon-small-smile.gif[/img]
Regards,
GLWBEAR
Old 12-07-2003 | 06:22 AM
GotDirt's Avatar
You can put paddles on almost anything. You don't have to run 23" tall tires. The sand is going to suck the power out of your quad. eight paddle max
suzuki230
07-08-2016 11:03 AM
Quadzilla Heritage
09-25-2015 02:39 PM
08-26-2015 12:16 AM
Nelson
06-22-2015 04:51 AM
Nelson
06-20-2015 02:59 PM
