In-line cooler....
Old Dec 7, 2003 | 10:29 PM
Yamaha660R's Avatar
Default In-line cooler....
Anyone running one of the in line coolers that cool your radiator fluid???
There are several differnt designs, and I was wondering if anyone has one because I'm purchasing one for Christmas and was wondering your guys opinions.
Old Dec 7, 2003 | 10:34 PM
hoover7's Avatar
If i was to do it over again i would not buy it. I have one on my DS...and well....cant tell a difference to be honest I put the temp gauge on it and the only reason it dropped is casue the purple ice i think. Try it if you want but $25 is a lot for takin a chance
Old Dec 8, 2003 | 11:16 PM
Yamaha660R's Avatar
Maybe I'll just put Engine Ice in my Radiator and be done with it.
Old Dec 8, 2003 | 11:21 PM
pudljumpr's Avatar
CFM makes some big 20 fin inline coolers that do make a 10 degree difference. Also, If temperature if freezing temps is rarely and issue, use purple ice or redline water wetter, will drop temps better than engine ice, all you add is a couple cap fulls with straight distilled water.
Old Dec 9, 2003 | 12:17 AM
lilnotts's Avatar
i have one of the big ones, not sure on the number of fins, but i got 2 off ebay for like 35, and it works great, works better than the engine ice did
Old Dec 9, 2003 | 01:59 PM
slappie's Avatar
Does engine ice have freeze protection?
I've got straight Engine Ice in my Raptor and it does get below freezing sometimes here in good 'ol TEXAS.
Should I drain it, flush, and re-fill with regular coolant for the winter?
Old Dec 9, 2003 | 02:19 PM
PaulStanley's Avatar
I've been running Engine-Ice in my grizzly for about a year now, seems to work ok. On the bottle it says it's good to around -24F. So living in Texas your good to go.
Old Dec 9, 2003 | 02:40 PM
BlueLeader's Avatar
the thermostats keep the motor at opperating temp. if the motor is hot and the thermostats are open promoting circulation I don't think a 2 or 4 inch finned tube will make a difference. not enought surface area. I would spend my money on the higher quality more advanced coolent or a larger radiator.
Old Dec 9, 2003 | 02:42 PM
vquad's Avatar
i drained the factory coolant out of my yfz450 and added the engine ice and a cfm 20 fin inline cooler...
not a lot of money for the added insurance...remember...heat is the enemy of horsepower!
Old Dec 9, 2003 | 04:54 PM
Dfitz's Avatar
Who has an oil cooler on there Raptor? I run 2 coolers, engene ice and going to add a oil cooler. I like to run hard and don't want to worry about heat. I don't want a temp gauge because I would be looking at it all the time.
SonicBoomNH
Apr 15, 2006 06:25 PM
DSengineer
Apr 5, 2005 12:10 PM
Bradracer18
Oct 12, 2004 11:56 PM
E
Feb 8, 2004 11:48 PM
