Big beaR 350 TOP SPEED?
Old Dec 17, 2003 | 06:37 PM
atvguy217's Avatar
Default Big beaR 350 TOP SPEED?
Hey i have a 1997 big bear 350 and i was wondering what the top speed on it is, and how can i make it faster? by the way its a 2x4 thanks.
Old Dec 17, 2003 | 08:08 PM
NovaSS's Avatar
Faster or quicker? These are two different things, top speed / accelleration is regulated by final gear ratio , tire diameter , rpm ( rev limited ) and total power out put. What works to increase top speed doesnt always make a better hole shot.
For top end try going to a taller tire but you will need a little more power.
Making it breath is always good start. SUPPERTRAPP makes a slip on IDS2 muffler, that and a K&N air filter and going up two jet sizes ( and maybe a dyno jet needle ) with give you a little extra feel in the seat of the pants.
Old Dec 18, 2003 | 12:27 AM
atvguy217's Avatar
ok thanks
Old Dec 18, 2003 | 01:13 AM
oldyeller's Avatar
Our 91 big bear 4x4 does 41 mph on radar.The two wheel drive should go a little faster than that.Ours does sound like it needs another gear at that speed.I know this sounds pretty slow but I find a lot of the speeds posted for quads are greatly exaggerated.
Old Dec 18, 2003 | 01:29 PM
atvguy217's Avatar
ok well the speedomettter on my says it goes around 38mph
Old Dec 22, 2003 | 02:07 PM
SpDdEmOn's Avatar
overall, low 40's give or take a couple due to mass production.
Old Dec 24, 2003 | 08:50 PM
Andy Bassham's Avatar
I would think that if its running like it should, you ought to be able to get around 48-50 out of it on pavement after letting it wind out completely. My 89 Honda 300 GPS'd at 51 maxed out. Took a while to get there, and the slightest grade brought it back down to the mid 40's, but the Big Bear should be a lot better than just 38.
I did the GPS test on the 300 the same day I did it on my old 99 AC 500. The Arctic Cat would go like 52.8 or something. Not much faster overall than the little honda, but it didn't lose speed as much on grades, and it got there a lot quicker. GPS on my 660 told me 60mph flat even. Speedometer said 65 at the time.
I think a 2wd Big Bear will be both quicker and have a higher top end than the 4x4 though.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
black_thunder
Sep 6, 2015 04:41 PM
Brandon400
Sep 5, 2015 08:44 PM
