cant change oil!!
Old Dec 18, 2003 | 05:44 PM
  #21
Just4Kicks's Avatar
Default cant change oil!!
Originally posted by: Roach007
If this is the same as the Wolverine I had to use a pipe wrench. Get on the edge and it should come off without hurting anything. I know I will get ripped for this, but it worked for me. I also had to do this on my buddies. You only have a small lip to work with but it will work. Start the motor and let it warm up before you do this though.
What the!?!?!? You can't do that!!! LOL.....just kidding man.
Actually I never thought about that. Those pipe wrenches have some serious bit. I don't see why that wouldn't work.
Old Dec 18, 2003 | 06:53 PM
  #22
Nicname's Avatar
Have you tried chiseling out the bolt. I have had to do that to some of our quads, mostly a Yamaha Breeze. Just take a good metal chisel and cut a small notch in the shoulder of the bolt. Then use the notch to drive out the bolt counterclockwise with many small pecks from a hammer and punch. The vibrations from the hammering on the chiseled edge should make it come out. If all else fails, there is always the drill.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
