kodiak valves
Old Dec 20, 2003 | 07:37 PM
rda's Avatar
rda
Default kodiak valves
hi,
03 kodiak, 68 hours, running fine..before
I decided to check valve clearance since manual said to, I had a photocopy from my dealer on the procedure. The valve were within spec but on the tight side so I loosened them to the be in the upper middle. after starting it back up, it won't idle right. it is idling real rough. It makes good power though.
Is my problem most likely the valves are not at the right clearance now? Maybe they moved when tightning the locknut?
Could there be any other cause?
I am waiting on the engine to cool back down right now and I plan to check the clearance again.
Old Dec 20, 2003 | 08:20 PM
Seppi's Avatar
Just wanted to make sure if you did this adjustment when the engine was cold or hot . Should be done after the engine has been shut down for a few hours !!!
Just my 2 cents ?
SEPPI
Old Dec 20, 2003 | 08:33 PM
rda's Avatar
rda
it was definately cold, hadn't been ran for about a week.
Old Dec 21, 2003 | 10:11 AM
Seppi's Avatar
O.K rda now that we got that out of the way.And we know the valves were adjusted right ???? I would go ahead and have my carb... idle mixture reset and after that is done I would check the base idle setting . By the way this is normal procedure on any four stroke!!
Seppi
P.S.. I own a 2000 Kodiak and I haven't had a burp of trouble with it yet !!!! {Touch wood }
Old Dec 21, 2003 | 10:26 AM
rda's Avatar
rda
Thanks, but I found the problem. When removing or reinstalling the tank, I accidently pulled the choke cable tube partially out of the carb which made the choke stay on. DOH!
Old Apr 24, 2006 | 03:25 AM
ixRAZORxi's Avatar
Whats the clearenaces ands procedure for an o3 400 kodiak?
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
