Using Winch
Old Dec 20, 2003 | 11:17 PM
NewBoy22's Avatar
Default Using Winch
I want to use the warn winch on my Grizz to pull some rocks (around 200lbs each) from the back to the front of my house. any ideas on how to do this or should I create some kind of sling and tow the rocks.
thanks
Old Dec 21, 2003 | 12:25 AM
Kraw's Avatar
Default Using Winch
I wouldn't use the winch to drag it. The only way you should use the winch is if you are stationary and you want to pull something to you, or if you want to pull yourself to something, say a tree. Never hook your winch to something and pull, using the bike to pull the object. Always let the motor do the work on the winch.
Does that make any sense? [img]i/expressions/face-icon-small-blush.gif[/img]
Old Dec 21, 2003 | 12:41 AM
NewBoy22's Avatar
Default Using Winch
Ok, If i somehow hook up the winch to a rock could i not just pull the rock to me using the winch motor if I am stationary??
Old Dec 21, 2003 | 11:12 PM
YAMABEAN's Avatar
Default Using Winch
just take the $250 youd have to spend to replace your winch from misuse, and go to thew local caterpillar store and rent a skidsteer for the weekend. you can do those rocks and a lot more all in the same whack. bean
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
