Stage 2 cam gains on top end?!?!
Old Dec 22, 2003 | 09:08 PM
AustinONeal's Avatar
Default Stage 2 cam gains on top end?!?!
lets says a raptor like mine runs 75 then put a stage 2 cam in how fast would it go?
Old Dec 22, 2003 | 10:48 PM
Yamaha660R's Avatar
You would pick up more speed by changing your gearing.
But the stage 2 cam gives you lots of power on the top end, and you will be able to pull a higher gear that gives you more speed.
Old Dec 23, 2003 | 12:22 AM
BigScary's Avatar
yeah..........I went from a stage one to a stage 2 cam..........I will say that the stage 2 deffinately made mine pull th higher gearing easier..........I would bypass the stage one all together........
I wouldn't believe anyone that says that you are gunna lose tons of low end.........BULLSH!T........I didn't.........
if you install any kind of high comp piston (11:1+) at the same time then you will prolly, actually gain someon bottom..........
or I DID!!!!!!!!!
JMHO!
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
