Blaster top speeds
Old Jun 24, 2000 | 01:06 AM
gomer's Avatar
Can someone tell me the real top speed of the Blaster. I am thinking of buying one.
Old Jun 24, 2000 | 07:15 AM
moto4DX's Avatar
the blasters top speed is approximately 54-56 MPH stock with a few mods this can easily exceed 60. This questions usually starts a lot of arguements during post, but if you are asking to see if its faster than a 300EX, Mojave, TrailBlazer, the answer is yes, there is actually a toss up between it and a warrior, A Blaster is much quicker than a warrior because it is two stroke but top end really depends on the rider. Good luck with your purchase.
Old Jun 24, 2000 | 04:40 PM
94DGblaster's Avatar
I settled the trailblazer vs. blaster yesterday.
I raced a guy with a modified Hotseat/RCR Trailblazer and passed him up in 3rd..hit 4th 5th and 6th and he was so far back it wasn't funny. I got a bad start, i had it in neutral.
Old Jun 24, 2000 | 06:39 PM
A99wolverine's Avatar
Yes thou is de homosexu@l
Old Jun 24, 2000 | 08:45 PM
roadkill's Avatar
I've successfully hit 55mph on a stock blaster... I think with sufficient room I could probably hit just over 60mph at flat out.
Old Jun 26, 2000 | 01:09 PM
muddobber's Avatar
they clocked mine running 57 mph stock ..
but now i can run over 70 with a few mod.
98'blaster, 190' Doulgas rim's on blackwaters
wiesco piston , DG grab bar , fmf pipes ,pj/34mm carburetor,uni air filter , jet kit ,fmf reeds
Old Jun 26, 2000 | 03:04 PM
sAyIt_fmf's Avatar
for real people!! maybe 55-60 if your lucky...if you get into boring and other mods maybe a bit faster but not much
Old Jun 26, 2000 | 03:12 PM
I'm sure is he pretty light.
I seen a CT 240 blaster do 74.
The guy also had 14 tooth sprocket and weighed in at around 170. But that was a site to see!
Old Jun 27, 2000 | 06:26 AM
JIGA's Avatar
Last week me and my friend went out to a beech and rode, pretty fun on the blaster but, the shocks are stock and set a stock settings. Im 21 5'11" and about 140lbs, what is a good setting for the front and rear shocks, right now I have the fronts on setting "c" and the rear I cranked abut 1 1/2 turns on the bolt.
I got it out on some pavement and wrapped it out to 6th gear, I was really flying, and its stock, pipes should be gettin here in about a week
Old Jun 27, 2000 | 03:21 PM
xepathfinder's Avatar
My Warrior never even came close to losing to a Blaster.
