blaster oil injection
Old Jun 24, 2000 | 01:51 AM
b(250rman)'s Avatar
I just showed my dad the blaster piston and he said it looked like the oil injector quit working. Is there anyway to test this???? and also about the oil injector block off kit how easy are they to install????? do they work good?? any help would be greatly appreciated
moded 86 trx250r
moded 87 LT500R
97 300ex
96 warrior
90 blaster.
pics coming soon for all.
Old Jun 24, 2000 | 06:05 AM
Blastermaster's Avatar
hey man the my frinds 310r seized up and it looked like the piston started to melt if that is what yours looks like it probally quit (i took mine off before it had the chance )in the clymer manual there is a section on how to test the injector
as for blockoff kits i got mine from t&m desigens and havent had a prob instlation: 1 drain oil: 2, take off injector cover: 3, remove hoses drain&remove oil tank: 4, take hose off carb and cover oil intake hole on carb: 5, take off kick starter: 6, lossen bolts on main side cover (find a way to keep them in order they ARE difrent seizes: 7, remove side cover and remove old gasket: 8, take off little plastic gear and remove oil injector (2 screws and a little wiggeling ) and remove old gasket: 9,take new gasket and blockoff plate and use supplied bolts and some locktite to bolt down blockoff plate: 10, reinstall kickstarter gear (make sure the "kick stop" is at the top0: 11,while holding the gear inplace slide sidecover&new gasket over the shaft on the gear and hold the side case on and make sure it works before bolting down the sidecase: 12 ,if it works bolt on the side case and you are done
Old Jun 24, 2000 | 09:38 AM
94DGblaster's Avatar
here is a picture of my piston after the oil injector stopped.
http://www2.1st.net/ar15/pistontopside.gif
Old Jun 25, 2000 | 11:11 PM
EdSmith's Avatar
Why does everyone blame the injector every time they sieze a Blaster? Other things can brake you know...
BTW: The first quad ever to finish the (6000 mile plus) Paris-Dakar rally was a Blaster running oil injection. Never siezed up. Hmmm...
BTW II: Anyone see the Rally Banshee in an ATV Action mag a few months ago? He ADDED oil injection. Hmmm... I think I see a trend...
My Blaster is oil injected, after 5175 miles, I've yet to have it quit. Call me stupid, but I'm not a bit worried.
Old Jun 25, 2000 | 11:40 PM
miker567's Avatar
I have a 1972 suzuki 100 enduro with oil injection that still works, however I am wondering about my 2001 blaster from what I have read here, i don't know what to think, my dealer hsays he has never seen one go bad??? I doubt he would tell me if he had though?
Old Jun 26, 2000 | 12:20 AM
hey man i would go ahed and take the injector off i got mine for christmas in the gear was already starting to loose teeth
Old Jun 26, 2000 | 12:29 AM
b(250rman)'s Avatar
couldn't U just not put 2 stroke oil in the injector. and just premix it anyway????
Old Jun 26, 2000 | 12:30 AM
miker567's Avatar
Are you serious ??? It was only a few months old??
Can i just take it off or Do i have to buy one of those kits if so why???
Old Jun 26, 2000 | 12:56 AM
all you have to do is take off the side case and take off the little plastic gear
that is what it said to do in dirt wheels (mix at 32:1)
Old Jun 26, 2000 | 09:46 AM
I know my injector was bad.
There was dirt on the piston and a few teeth were missing on the gear.
