rev limitor bypass?
I have a 02 grizzly 660, same wiring i think. Under the left side panel there is a green wire with a white tracer. Unhook this wire and your reverse light should be on. Then take the female end and ground it to the motor, and your reverse light should now be out. This should bypass your reverse limiter. The front diff lock limiter you will need to take the seat off. On the cdi there is a group of three wiring plugs. on the bottom group of wires there is a white wire. You will need to cut the white wire and this will eliminate the rev limiter for the diff lock. Be carefull because you will be able to lock the front end at any speed. Might be a good idea to install a toggle switch, although i did'nt and havent had any problems. Good luck
jrooker6
Apr 23, 2016 07:36 PM
