Will Banshee Shocks Fit On a Blaster So It Would Have More Ground Claerance?
Is it possible to fit banshee front and back shocks on a blaster frame for ground clearance without making modifications to the shock studs or the frame....???? Thats all I wanted to know...
Thanx...
Bloody
the front shock will fit, but the back one wont, u'll have more ground clearance up front, but cuz it sits higher up, itll be more tippy, and the bansee is quite a bit heavier than the blaster, so the shocks'll be a little stiff, but they work, but u cant make the back one work
it wouldn't gain ne groung clearance. but if you wanted better shocks get sum works shocks or sumthin they can set up your shocks the way you want them.
