Please help with crazy raptor problem!!!!!.............
Old Dec 29, 2003 | 01:44 PM
Roughedges's Avatar
Default Please help with crazy raptor problem!!!!!.............
THANK YOU KUZ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
Your my christmas hero!!!!!!!!
i said i dont got a parking brake block off but screw it. i took the one connector off and left the two butt connectors on. BAM!!!!!!! Perfect and hauling *** like never before. damn the jet kit, proflow intake, headpipe and t4 made a HUGE difference over my white brothers e series
thanks guys, your great [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 29, 2003 | 11:11 PM
duneittilludie's Avatar
ROUGHEDGES-The reverse problem that you described happened to a friend of mine on our last dune ride and i will try to describe what we did to fix it.If you will follow the cable down from your reverse **** you will see that on the left side of your motor near the bottom of its mounting points there is a sleeve on your cable that fits into a hole that is stationary.If this sleeve gets removed from its mount point it will keep your reverse from working properly(it will go into reverse without the switch engaged)so put the sleeve that is on the cable back in its mounting point and you should be good to go.
KimSJoh
14
Jul 18, 2015 07:20 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
