Kodiak - Skid plate with plow?
Old Jan 1, 2004 | 03:16 PM
SammyZ's Avatar
Default Kodiak - Skid plate with plow?
Hi. I recently installed a cycle country plow on my Kodiak. To do so, I had to remove the plastic skid plate. Is there an aftermarket skid plate that will work with the plow mount?
Thanks
sz
Old Jan 1, 2004 | 04:53 PM
Hozed's Avatar
your best bet would probably be to go to your dealer and check with them. they should be able to look in after market ctatlogs and tell you if they got em.
Old Jan 4, 2004 | 11:32 PM
SammyZ's Avatar
Thanks, but I'm trying to avoid my dealer. The last time I talked to them, they wanted $330 to install a winch and plow. That was an hour's worth of work for me, and I assume they could have done it even faster.
Anyone else have a suggestion? Is there a good place online selling Kodiak stuff?
sz
Old Jan 5, 2004 | 07:29 AM
atv123's Avatar
I have a Moose plow and the plow mount bolts on directly below my factory skid plate on my Kodiak. Are you sure you have to remove your skidplate for yours to bolt on?
Old Jan 5, 2004 | 02:52 PM
Kodiac400's Avatar
My thoughts are the same as atv 123's. Are you really sure you have to take the skid plate off. I have a Kimpex plow on mine and it bolts right on top of my skid plate. What seems to be the problem? Bolts to short or holes in the wrong place?
Old Jan 5, 2004 | 04:40 PM
95Wolverine's Avatar
Well, I feel his pain. I purchased a Warn and the mount goes on top of the mainframe rails. The horseshoe bolts go around the frame and thus the skidplate is in the way. I simply cut slots in mine (well simply might be over simplifying it.. machined slots in the aluminum) to allow the skidplate to be on with the horshoe bolts in place.
As for finding a skidplate already like this... good luck.
Ride On.
Old Jan 7, 2004 | 11:17 AM
vmaxamillion1200's Avatar
I guess I should have checked this board before I installed my Kimplex plow. As the instructions for the mount say that the skid plate must be removed first , now the last foot and half of the plastic plate towards the rear is only seated against that plate due to it's elasticty. Maybe I'll take if off and put the mount on over the skid plate.
Old Jan 8, 2004 | 07:41 AM
atv123's Avatar
Makes me glad I bought the Moose plow [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 8, 2004 | 12:30 PM
RED5's Avatar
Yeah I put a cycle country plow on my Kodiak 450 and even though the directions said to remove the skid plate you don't have to, I left mine on.
shimanok2
Jan 29, 2016 07:37 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
