NEED BANSHEE HELP ASAP
Old Jan 3, 2004 | 11:40 AM
HiFlyinRaptorRyder's Avatar
Default NEED BANSHEE HELP ASAP
Alright guys I'm going riding in a few hours so I need some quick anwsers. First of all, with Toomey T-5's, air filter and reeds, I run 32:1 with Yamalube. I wont have any time today to get anywhere to buy Yamalube so I had to buy Castrol last night. I got my manual out and looked and it said it run 24:1 with Yamalube and 20:1 with Castrol. Running the castrol 32:1 would mean I need to put 20 ounces into my gas(5 gallon container). Do you think I should put 20 ounces in or maybe bump it down to around 18 ounces? PLEASE HELP ASAP
Old Jan 3, 2004 | 12:53 PM
WheelieKing's Avatar
If you run it at 32:1 you put 20oz in a 5gallon container, if the books says run it 20:1 then you would run it richer at 32oz for your 5 gallon container. So you would run it richer. I’d run it 32:1.
Old Jan 3, 2004 | 02:34 PM
Hiram's Avatar
That's right the lower the ratio the more oil per gallon, You will be fine with 32:1 and I wouldn't change it with out rejetting. You could run lean if you lower the ratio and run more oil per gallon.
Kaleb_00
Jun 1, 2016 09:15 AM
slowgsxr97
Sep 8, 2015 07:33 PM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
