best clutch for raptor
Old Jan 3, 2004 | 07:38 PM
ccgrady's Avatar
Default best clutch for raptor
i have a 02 raptor with a 686 kit. my stock clutch hasnt started slipping yet but i would like to go ahead and get a better clutch and replace it now instead of when im out ridding on a weekend and lose it. who has the best clutch?
Old Jan 3, 2004 | 07:46 PM
caliraptor's Avatar
GYTR clutch kit and Clutch basket.
Old Jan 3, 2004 | 08:22 PM
Yamaha660R's Avatar
How hard is it to change the clutch in a Raptor???
I need to change mine. [img]i/expressions/face-icon-small-blush.gif[/img]
I think I'm going to order the Tusk Heavy Duty Clutch Kit w/ heavy duty springs.
Old Jan 5, 2004 | 01:23 AM
UBETRUN's Avatar
The clutch swap is pretty easy once you get the cover off:-) It's a little harder to change the basket, you have to grind down the rivets in the stock basket without hitting the gear. Getting the cover on and off is the hardest part of the job, make sure you put the lower left bolt in the case cover before you install it.
Old Jan 5, 2004 | 08:38 AM
ClutchOlds's Avatar
Yamaha660R, let me know how that clutch is. We are thinking about trying that one on a buddies, Raptor. Thats a good price on them. Was wondering if they were to cheap??
Old Jan 5, 2004 | 08:41 AM
Yamaha4eva's Avatar
you wont spend more then 50, likely alot less
Old Jan 5, 2004 | 11:00 AM
UBETRUN's Avatar
If you've got the $$, Craycraft is now selling a 6 spring Raptor clutch kit from Hinson. Comes with billet Hinson basket, pressure plate, and hub. Stock and other aftermarket clutches are 5 spring, the 6 spring should be plenty strong enough for a built motor.
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
