Increase / Decrease nut on Wolverine
Old Jan 9, 2004 | 02:52 PM
gdcharlton's Avatar
Default Increase / Decrease nut on Wolverine
I have a quick question regarding my wolvy (1999)....
Beside the pull start there is a nut with a increase / decrease arow. What is it for????
Thanks
Greg
Old Jan 9, 2004 | 07:59 PM
Hedgehog's Avatar
ANy answers anyone, I too would like to know!
Old Jan 9, 2004 | 08:02 PM
MichaelAZ's Avatar
its for your clutch
Old Jan 10, 2004 | 03:49 PM
SpDdEmOn's Avatar
Yes, its for clutch adjustment. It works a little different on mine, because I have a manual clutch, it adjusts the play in the clutch lever.
Old Jan 20, 2004 | 07:27 PM
Roach007's Avatar
I know the answer to this question was posted a while back but can't find it. My clutch is slipping in 3rd and higher which way do I turn the screw. Decrease or increase.
I just had the clutch replaced and trying to fine adjust it.
Old Jan 20, 2004 | 09:11 PM
SpDdEmOn's Avatar
First try turining it to the left (counter-clockwise) and that should clear it up, but if im wrong, then go clockwise untill it clears up. If you turn it wrong and it gets worse, dont worry about it, you didnt do any permanent damage, just correct it. Dont be afraid to mess with it, thats how you learn. I dont remember which way was increase or decrese, I would have to look at the engine, but when you turn it left, it backs the bearing plate off of the button thats used to engage the clutches, therefore making them release sooner and not dragging out.
Old Jan 20, 2004 | 09:29 PM
Roach007's Avatar
Thanks Again
Old Jan 21, 2004 | 01:52 AM
SpDdEmOn's Avatar
Anytime man
Old Jan 22, 2004 | 04:59 PM
Reed8494's Avatar
I was wondering where you go for the clutch kit and with an r4 pipe on the wolverine with a k&n w/precharger as well as drilled and uni vented air box lid how many sizes should I go up with my jet?
Old Jan 22, 2004 | 05:41 PM
SpDdEmOn's Avatar
Well, with your intake and exhaust modifications you are going to need to jet it richer. How rich I cant say, you will need to figure out going one step at a time. It can be diffrent for each person. Are you wanting to drill your clutch plates or go to a maunual
mtdewmn
Jan 19, 2017 12:13 PM
2many2ride
Sep 27, 2015 04:35 AM
metal249
Jul 24, 2015 01:00 PM
Jul 23, 2015 07:53 AM
ltrmc02
Jul 22, 2015 04:50 AM
