Raptor Oil Level...??????
Old Jan 10, 2004 | 12:12 PM
Too's Avatar
Too
Default Raptor Oil Level...??????
Ok guys..got another one for you....I changed the oil in my raptor and let it run for a few min. and shut it off....let it set for a bit to check oil....Well did not screw dipstick in, as manual says and the oil level was barely reading....So i pour some more in....I ended up putting about a little almost 2 1/2 quarts in.....is this bad?????? I rode it and checked it seems good......I did change filters also during this maint. Thanks...Textconfused;
Old Jan 10, 2004 | 12:30 PM
Hozed's Avatar
2.5 sounds right.. i put 2.25 in my pred...
Old Jan 10, 2004 | 12:42 PM
sixsixT's Avatar
I fill mine to the bottom of the safe area when it's still somewhat cold and after it warms up a bit it's at the full mark. It takes about 2.25 qts. with the Bosch filter.
Old Jan 10, 2004 | 12:53 PM
FISHER1648's Avatar
Yep - I pretty much stopped trying to use the dipstick to determine oil level - it's never the same. I add 2.25 each time and go with it. Also, it's helpful to keep track of how much you drain out just so you know everything makes sense.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
