Domes for cool Head
Old Jun 28, 2000 | 08:59 PM
FMF's Avatar
FMF
I would like to get smaller Domes for my Banshee and I still would like to run pump gas.
I have 22cc Domes now
Old Jun 28, 2000 | 11:43 PM
BansheeBill's Avatar
What altitude do you intend to ride? From what I have been told, once the cylinder pressure gets above 150 psi you should consider running racing fuel. I think (not sure)Pro Design has a web site that lists the psi at specific altitudes for each size of dome that they offer. If not, I'm sure that their tech's could answer your question. I currently run 19cc domes and produce 150 psi here in Phoenix (roughly 1,600 ft. alt.) I run 100% race fuel. I was told that I might get by with a 50/50 mix but that 100% race fuel will run cooler. Also, I primarily run at Glamis where the cylinder pressure will increase to about 180 psi. Definately need race fuel there.
Old Jun 29, 2000 | 12:54 PM
FMF's Avatar
FMF
The altitude is below 3000
Old Jun 29, 2000 | 01:02 PM
morvac's Avatar
Also if you can get a hold of a rockymountainatv
catalog, it has a complete chart of the PSI/elevation/dome size configuration one might have. Go to www.rockymountainatv.com and order it online if you don't have it....
Old Jun 30, 2000 | 01:42 AM
scottd's Avatar
I've tried them all. You probably will be able to get by with 21cc domes w/ pump premium. I use 19cc domes with 50/50 mix of pump & race fuel, and it rocks! Tried 18cc domes also and was not satisfied with top-end and over rev ability. These are to compensate for higher altitude and add more low-end torque. Bust out some cash and use at least a mixture of partial race fuel...it's worth it.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
poutlaw525
Sep 9, 2015 03:19 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
lancemll88
Sep 5, 2015 03:16 AM
