1998 yamaha grizzly tranny problems please help
as you can see from above i have a 1998 yamaha grizzly and have never had a problem, i use it mostly for plowing we have been having colder than normal temp's. I started the quad right up but couldnt shift it into gear after letting it run for a little while I was able to get it into rev. but no into forward. I made the mistake fo leaving it into reverse when i placed it into my garage and now i cant get it out of reverse either has anubody out there had similar problems or can you offer me any ideas it would be greatly appreciated thanks in advance paul[img]i/expressions/face-icon-small-confused.gif[/img]
Chances are your engine is running a little too fast. If everything was working fine before then you may find that your choke cable is sticking slightly, more than likely caused by icing in the cable. Can you turn it off then shift it into the gear you want, then restart it? Beyond that, perhaps you have some snow / ice interfering with the shift linkage. One way or the other I bet you are experiencing an icing problem…
RANGE ROVER THANKS FOR YOUR HELP, I HAD A FRIEND COME OVER TODAY AND HELPED ME LOOK OVER MY BIKE WHAT HE FOUND WAS VERY NICE SEEMS THAT AFTER I WOULD WASH OFF MY BIKE AFTER I PLOW @ HERE IN THE SALT. WATER SEEPED INTO THE SHIFTER BOX PAST THE BOOT AND FILLED WITH WATER AND FROZE SOLID SO WE TOOK IT APART CLEANED IT UP SPRAYED IT DOWN WITH A LOT OF WD40 AND IT SHIFTS BETTER THEN IT EVER HAS THANKS AGAIN MUCH APPREC. PAUL
toonces
Oct 16, 2019 12:11 PM
RticKwad
12
Jul 19, 2015 12:22 AM
ranvette
Jul 4, 2015 06:13 PM
