oil change
Old Jan 21, 2004 | 04:41 PM
brian1414's Avatar
Default oil change
how often to change oil on a four stroke quad?
Old Jan 21, 2004 | 04:49 PM
RoostItUp's Avatar
Default oil change
I change my oil every 5 er so rides unless I'm breakin it in then I change it every couple and make sure I get the valves adjusted.
Old Jan 21, 2004 | 04:50 PM
AlphaRaptor660R's Avatar
Default oil change
I guess it probably depends how much and how hard you ride it...I change mine after every 2 major trips, which will roughly equate to about 15-20 hours of riding...
Old Jan 21, 2004 | 04:51 PM
brian1414's Avatar
Default oil change
how do u change the oil...like how do u drain it
Old Jan 21, 2004 | 04:55 PM
shadowmaker's Avatar
Default oil change
Take the screw out of the drain plug. Let it drain until it just about stops dripping. You can jack it up on one side so that its tilted towards your drain pan.
They told me to change it every 10 tanks of gas. Dont know if this right. I dont have a speedo or hour meter to measure. I figured I go about 5 and see what it looks like. If it needs it, I ll change it.
Brad
Old Jan 21, 2004 | 04:59 PM
brian1414's Avatar
Default oil change
thanks alot really appreciate it
Old Jan 21, 2004 | 05:12 PM
Default oil change
Dont forget to change the oil filter also. When u put the new back on, take a little oil from a new bottle and wipe it around the rubber seal. Just dip your finger and wipe around it is all I do. Then pour a little oil in the filter so that when u start it up, the filter has some oil in it.
Brad
Old Jan 22, 2004 | 08:54 AM
atv123's Avatar
Default oil change
Hey shadow - where in VA are you located? I'm up in Fairfax.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
