210 psi. Uhh ohh
Old Jan 24, 2004 | 03:02 PM
roosthrower's Avatar
Default 210 psi. Uhh ohh
I got a serious problem. I just installed vitos power pistons in my banshee and after a simple compression check I was stuned. They raised the compression all the way up to 210 psi. I can't believe this crap. Does anyone know a way to lower the compression at all? Should I just install some new pistons? I would appreciate any help.
Old Jan 24, 2004 | 03:04 PM
trailrider500's Avatar
Get a hemi head and use domes... That will lower compression
Hozed's Avatar
210? that aint right from just pistons.... did you have the throttle open all the way.. i dont think it matters that much tho...
Old Jan 24, 2004 | 03:06 PM
I can see 210 from pistons its very possible... Having the throttle open all the way will change the compression psi reading about 10-20 psi
Old Jan 24, 2004 | 03:07 PM
JakalWarrior's Avatar
They have a serious dome to them or something? Obviously they dont match the head in your machine and youll probably destroy a piston if you run it like that.
Old Jan 24, 2004 | 03:08 PM
I'm guessin that it has some head work that I didn't know about.
Old Jan 24, 2004 | 03:10 PM
the dome is a little more convex than what was in it. there wasn't a much of a difference.
Old Jan 24, 2004 | 03:11 PM
That could be very possible, Best thing to do is get a different head.. you will be better off in the long run[img]i/expressions/face-icon-small-smile.gif[/img] and a good reason to spend money...
Old Jan 24, 2004 | 03:15 PM
Dosent take much of a difference when working with tight specs. It could also mess with the squish.
Old Jan 24, 2004 | 04:07 PM
420EX's Avatar
loosen the spark plug lol, j/p
