+2 or +3 A Arms for my raptor????
I am going to be purchasing some Lonestar +3+0 Racing A Arms for my 02 Raptor..... I am now second guessing myself if the +3's are going to be too wide and if i should go with the +2's instead....i do all types of riding, roal road lines, open trails, fast and slow trails, some tighter trails but not too bad and thats only prob 5% of my total riding barely ever.......if you are running wider a rms on your raptor could you please give me some suggestions, i am also going w the +5 RPM Axle
Thanks in advance
Thanks in advance
With +3 a-arms and stock or 4/1 offset front rims, you'll be right at 50" wide. With 3/2 rims, you'll be 52" wide. 50"-52" is pretty wide for trail riding but it can be done if you are very careful in the narrow spots. Depending on the rear wheel offset, you should be 50" with the RPM +5 axle. Your rear tires will stick out past your nerf bars so be careful making tight turns around trees. What kind of shocks are you getting? Your Raptor will handle so much better with the new suspension, congrats!
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
