Almost finished with break-in on my grizzly?
What is the best way to wheelie? Can you just punch it in high range on flat groung and it do a wheelie? Or does it have to be in low? I'm assuming it will pull the front end off the ground on flat ground............
Thanks,
Thanks,
Mine would do it by just punching the throttle (while it was moving slow) before I put my winch on. After the winch it required a tug on the handlebars along with the throttle. However I don’t generally do it for show, I do it when I want to lift the front end over a log or ledge while trail riding, and that is quite often while going along at a pretty good clip. I just nail it , use some body english and it pops up just enough to clear the log or to at least skim over it…
kbazzy
Sep 26, 2015 11:26 AM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
