need help with an ailing raptor
Old Jan 25, 2004 | 01:04 AM
Raptor8tor's Avatar
Default need help with an ailing raptor
okay guys, I really need your help here. I have a buddy with a raptor set up exactly like mine. (see sig.) The bike idles fine but when in the upper rpm's it cuts out. We adjusted the valves and no luck. All the valves seemed a little loose but they are all within specs now as well as we can tell. We lined up the marks for TDC and set according to the manual. We have great power at lower rpm's but about half way through each gear it will cut out. Perhaps a carb problem? Battery and everything else checks out. Any help would be appreciated. Dont be afraid to post, we are willing to try anything at this point. Thanks guys.
Old Jan 25, 2004 | 01:24 AM
RaptorOwner's Avatar
Sounds like a carb problem to me. Did you jet the bike or change the settings on the needles? I would double check these things before you go any further.
Old Jan 25, 2004 | 01:29 AM
Raptor8tor's Avatar
the carbs were not touched before the problem came up. Possibly a clogged jet? thanks for the reply
Old Jan 25, 2004 | 01:48 AM
DragRaptor727's Avatar
it could be that the clip on the needles is on the wrong place. i think they call that a high/mid range miss or something [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 25, 2004 | 01:52 AM
Raptor8tor's Avatar
we are going to pull the carbs apart tomorrow and see if anything is obvious. Mine did the same thing in the midrange and moving the needle position worked. Thanks DragRaptor727, for reminding me of that. It would be pretty easy to check before pulling the carbs out. Any other ideas out there?
Old Jan 25, 2004 | 02:07 PM
Raptor8tor's Avatar
bump
Old Jan 25, 2004 | 03:01 PM
Customfabandweld's Avatar
Sounds like a clogged main jet, or clogged air filter. It could also be a faulty coil, not being able to provide spark at the higher RPM's. Good luck!
Old Jan 25, 2004 | 11:33 PM
Raptor8tor's Avatar
thanks Custom, we will check those things also. Didnt get a chance to work on it today, but we will tomorrow.
Old Jan 26, 2004 | 02:24 PM
garyc660R's Avatar
Could be the choke sticking and leading too a rich condition. His plug color should be almost identical too yours. I always pick up a couple cans of brake fluid for cleaning carbs.
Old Jan 27, 2004 | 12:43 AM
Raptor8tor's Avatar
hey guys, looks like it was the airfilter. We both use K&N and it appears maybe we put too much oil on it. That is a guess but we took the air filter off,cleaned out the airbox, and ran it up and down the street. Ran like a striped-a$$ ape through all rpm ranges. Thanks for all the input, I knew someone on here would come up with the answer. Thanks again.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
