Banshee problem
Old Jan 27, 2004 | 07:50 PM
runts's Avatar
Default Banshee problem
Hey the problem is that where the pipe and the round tube going to the silencer connect is spraying oil out the side of it. Not too
much but just dripping and its spraying all over the carbs and boost bottle. What is this???
Old Jan 27, 2004 | 08:02 PM
WheelieKing's Avatar
how much oil are you putting in the gas?
Old Jan 27, 2004 | 08:13 PM
runts's Avatar
8 ounces to 2 gallons of gas
Old Jan 27, 2004 | 08:17 PM
ohh. maybe you could run it with less gas. i had the same exact problem and there was unburnt oil all over the carb and expansoin chamber. i was mixin the same ratio as you. after that i switch to klotz R-50 oil and it burned alot cleaner, and didn't have the problem again.
Old Jan 27, 2004 | 08:33 PM
runts's Avatar
Dude thanks a bunch Ill switch over to that kind of Oil. Can you get it at your local yamaha shop?
Old Jan 27, 2004 | 08:37 PM
yes thats were i get mine at.
Old Jan 27, 2004 | 08:40 PM
runts's Avatar
Ok cool thanks again, maybe Ill have some luck
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
