Noss head or Cool head???
Old Jan 27, 2004 | 11:18 PM
runts's Avatar
Default Noss head or Cool head???
What head would be better for my banshee, My mods are below and I do trailriding and race in fields. What size domes too????
Old Jan 28, 2004 | 12:27 AM
PatsRaptor's Avatar
My friend has Wickeds head and it bad a$$ looking. Also has stud gurtles.
Pat
Old Jan 28, 2004 | 10:56 AM
bad350twin's Avatar
they are all nearly the same....but some have based off the cool head and made improvements.
Old Jan 28, 2004 | 02:07 PM
AlkyBurninX's Avatar
The newest NOSS head is the one to go with. I own two of them and a friend also has two. They are the best value and use stock studs along with the easy to find Pro design style domes.
Who ported your cylinders? What style porting do you have? This affects dome size. What gas do you run?
Old Jan 28, 2004 | 03:42 PM
Sheesnojoke's Avatar
Stock head is your best value.As long as you don't plan on changing domes.Have it milled&rechambered for about 150-160 psi and run a minimum of 94 octane or a race mix.I like the ability to run premium pump.Sometimes its hard to find the race stuff and it ain't worth melting a motor over.
Old Jan 29, 2004 | 10:49 AM
I was a firm believer in the milled stock head. I went from milled stock with 150psi to cool head with 19cc domes with about 150 psi and there was a significant power increase due to dome shape, squish clearance, and squish width. Milled stock is cheaper and will give a power increase though like sheesnojoke said, it is probably the best value but not if you plan on upgrading later.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
poutlaw525
Sep 9, 2015 03:19 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
lancemll88
Sep 5, 2015 03:16 AM
