HELP...raptor trouble
Old Jan 28, 2004 | 09:16 PM
DollarBillz's Avatar
Default HELP...raptor trouble
make sure the carbs did not pop out of the boots
Old Jan 29, 2004 | 01:05 AM
Slowwarrior's Avatar
Check the carb boots and also check the needle valve for your floats. Your problem is probably in the carb. Heres a good quick test. Take off your air filter and spray some starting fluid in the carbs while holding the throttle open not to much though then release the throttle and try starting it and see if it starts for a few seconds if that is the case its for sure that you are not getting fuel. In most cases its the needle valve that gets stuck in the closed position not allowing any fuel to get through.
Old Jan 30, 2004 | 05:47 PM
attitude's Avatar
thanks for the suggestions, i adjusted the valves and the raptor is up and flossin once again.....
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
