What can i do for a warrior?
Old Jan 28, 2004 | 04:44 PM
porto's Avatar
Default What can i do for a warrior?
I have a 96 warrior and i want to make it fast but i dont want to spend an arm and a leg. I plan on getting a pipe soon. Besides the pipe that i hope to get and i have a K&N air filter. I was curious what is the biggest and best bore i can get. Also any other modifications that i can do. If you can leave me the website or some information on where i can look at these parts. Thanks
P.S To answer back to this send me an email at mudslut96@yahoo.com
Old Jan 28, 2004 | 04:49 PM
dmljohnson's Avatar
you going to have to spend a little money.......speed cost, just order elka shocks for my bike over 700.00 bucks
Old Jan 28, 2004 | 04:51 PM
Eric250EX's Avatar
you can change sprokets for either top end or low end depending on what you want. i sujust you dont bore it out. do that once it starts to wear, if u bore it out now there wont be much left to bore out. right now the best to things for u is pipe filter and rejet it after those mods.
Old Jan 28, 2004 | 05:00 PM
caliraptor's Avatar
Pipe, jet 150-155, filter and cut the airbox, maybe get a 12T front sprocket. Youre looking at $300
Old Jan 28, 2004 | 05:13 PM
porto's Avatar
what kind of pipe and how cheap can i get it. What is the web site for it.
Old Jan 28, 2004 | 05:24 PM
caliraptor's Avatar
You can get a good used one on ebay, way cheaper than getting it new. You could also try
Rockymountain
Chaparral
Ebay White Brothers Pipe
Old Jan 28, 2004 | 07:59 PM
AngryHampster's Avatar
i just got a pipe, jet kit, and k&n filter for 300 bucks new from albaaction.com
Old Jan 28, 2004 | 09:07 PM
Crotts's Avatar
The biggest bore you can do without going stroker is 85mm or .080 over, but with that setup you will have to resleeve the jug if something happens and you damage the cylinder wall. A new cam and higher compression piston will give you a nice kick to your warrior. A good alternative to just cutting a hole in your airbox lid is here EHS racing. He sells a kit that uses a outerware to cover the hole in your lid so water and dirt dont get in.
Old Jan 29, 2004 | 12:56 AM
cidnitro's Avatar
90mm bore and 71.5mm stroke + money = H.P.
bore * bore * stroke *.7854 / 1000 = cc
90*90*71.5*.7854/1000=454.86 cc
Old Jan 29, 2004 | 03:25 AM
porto's Avatar
explain in detail what all those #s mean.
