blaster mods........
Old Jan 29, 2004 | 09:43 PM
BigScary's Avatar
Default blaster mods........
I think I've talked myself into getting a blaster for the g/f........
what kind of mods are available .............what would you blaster guys recomend? and also what are the costs on them and where can I get them?
pipe, filter, reeds etc.......
Old Jan 29, 2004 | 10:35 PM
niceman's Avatar
dont own a blaster but i have rode two (03 and a 00). get her a 04 or 03 if you can the disc brakes are much better than the old drums. its a small quad though. kind of a choppy ride. im 5''8 155 pounds and i felt a little cramped. for first mods deffinatly check out a K&N air filter. that cost about 35 dollars. a nice exhaust system would be this one by trenga racing (they make products exclusively for the blaster) the pipe is by trenga and the silencer is by LRD. check it out here http://www.trengaracing.com/catalog/...d6f5eab5ba678d
copy and paste and that will bring you there. hope this helps
Old Jan 30, 2004 | 12:07 PM
Shav0's Avatar
With a blsater the mods just keep going and going and going. It is a pretty small quad but it can be changed with some extended parts like a-arms and axles. If she isn't going to be doing much jumps then it can be easily widened by some wheel spacers but if money isn't a issue then defently go fro some extended parts.
Motor wise the blaster deffently has some potential. You can pipe it out with almost anything you want, thats just a matter of preference. Reeds and reed cages go easily on a blaster and work well with air filters and pipes. You can get these things almost anywhere. Try taking to your local dealer or go on e-bay.
Old Jan 30, 2004 | 12:29 PM
Yfz450VsBanshee's Avatar
The first mod i would buy would be a block off kit and mix your own gas. Then i would get toomey pipes and k&n air filter.
Old Jan 30, 2004 | 06:12 PM
raptorblasterracer's Avatar
do above and go to vitosperformance.net they r the blaster PRO's
Old Jan 30, 2004 | 06:37 PM
BigScary's Avatar
why would you do that?
not a consistant mixture?
Old Jan 30, 2004 | 06:57 PM
420EX's Avatar
no, the oil injection pump has been known to go out on blasters, never happened to my 92 blaster but i have heard of it happening to others.
Old Jan 30, 2004 | 07:09 PM
I would change it because the oil injector went out on mine. It only costs around 30 and is worth it.
Old Jan 30, 2004 | 07:26 PM
crispy's Avatar
Personally I don't think there's a big risk with the injection sysytem. Why would yamaha design something to fail?? yes you hear stories about them going bad, but think of the hundreds of blasters that have run flawless with them for years. If It makes you feel better you can, but would the g/f want to be mixing gas and oil?
First modds, razrs or holeshots they really do make it safer in a way.
Old Jan 30, 2004 | 07:32 PM
Lol look at how many things have "failed" on yamaha's before. My oil injection system went out about 6 months to a year after having my blaster.
