Reverse Front Rims on Raptor???
Old Feb 1, 2004 | 03:22 AM
Raptor660RR's Avatar
Default Reverse Front Rims on Raptor???
Reverse Front Rims on Raptor??? Is this a good or bad idea?? Why or why not??? Pros, cons??
Old Feb 1, 2004 | 10:04 AM
ShadyRascal's Avatar
Reversing the stock rims widens the Raptor about 5 inches. On ours, made a ton of difference. You need to get flush mount valve stems to do it. If you ride rutty or bumpy trails, you will experience a little bump steer, but for us duners its no problem.
Old Feb 1, 2004 | 10:52 AM
guardog's Avatar
Make steering more difficult and you will feel alot of shimmy at top speeds. Steering stabilizer may help but xtra $$$. I personally like it for the stability. to a bigger person, it will feel better. I also went with +4 durablue axle for the back REALLY WIDE !!!. I like the set up.
Old Feb 1, 2004 | 03:04 PM
HOBERT's Avatar
I did this to one of my old hondas i had. Instead of getting the flush mount valve stems i put standard ones in backward in the stock holes, and drilled new holes on the other side of the wheel for new stems. This won't work if you run tubes though.
Old Feb 1, 2004 | 03:51 PM
Shav0's Avatar
On some bikes, like the blaster, you dont even need to change the stems
Old Feb 1, 2004 | 03:57 PM
Raptor149's Avatar
Guarddog, is your signature right? A +8 axle? How about a-arms? Suspension?
You can reverse the rims, but like everyone says, bump steer, rough ride, etc... Douglas and ITP make offset rims to widen the front end, and they are stronger and available in beadlocks. I don't trust stock rims, bent too many of them.
Old Feb 2, 2004 | 02:02 AM
I have ITP C10 rims in back now and stock on front. Will C10s up front put the tires out alittle more or stay the same?
Old Feb 2, 2004 | 12:05 PM
2004LEBANSHEE's Avatar
Dont for get it gives the stock axle alot more stress when jumping and weakins hubs.
Reactant
Mar 30, 2022 02:08 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
