03 Raptor gearing
Old Feb 2, 2004 | 07:15 PM
Punker660's Avatar
Default 03 Raptor gearing
I like to climb fast and don't mind losing a little top end on the flats. Instead of a 2nd gear climb I would prefer to go up in 3rd. What combo do you guys run and what size chain to match?
Old Feb 2, 2004 | 07:41 PM
Dfitz's Avatar
Are you stock, what gears are you running now, what kind and size tires are you running and what are you climbing?
Old Feb 2, 2004 | 07:47 PM
AlphaRaptor660R's Avatar
you probably just need to drop one tooth on front...
Old Feb 2, 2004 | 07:49 PM
Punker660's Avatar
Right now they are stock sizes 13/40 I have 20" Holeshots and I'm not a "hillclimber" I would just prefer to climb everything a gear higher. I went to Glamis this past weekend and my bike just wasn't climbing everything as quick as I think it should. This is the first step. Thanks for responding.
Old Feb 2, 2004 | 08:12 PM
Yamaha660R's Avatar
12/42 should have you pulling the next gear up hard.
Old Feb 2, 2004 | 08:41 PM
Punker660's Avatar
That's what I was thinking but I would like to hear from more people. Thanks
Old Feb 2, 2004 | 09:58 PM
badrap02's Avatar
i run 13-44 and can pull sand mtn utah in 3rd and sometimes 4th
Old Feb 2, 2004 | 10:01 PM
badrap02's Avatar
i prefer to run this ratio because with a 12 on the front the motor has to wok harder
Hossblur's Avatar
I just went to the 12/42, go find wshrdskn, he has run the 12/42 for a while and help convince me
Old Feb 2, 2004 | 10:10 PM
Hossblur's Avatar
Punker- You just as well change the chain while your doing it. THe stock size is ok, you should have plenty of adjustment.
Banrap- Did you have to change chain sizes?
