Flipping the front Wheels on 2001 Warrior
Old Feb 3, 2004 | 03:41 PM
KGodfrey's Avatar
Default Flipping the front Wheels on 2001 Warrior
I Want to flip the front wheels around on my Warrior for better handling.
However the valve stems come into contact with the disk brakes. Can I
replace this valve stem with a shorter one, or do I need some sort of
spacer to widen the gap?
Old Feb 3, 2004 | 04:44 PM
Colby's Avatar
I ordered a set of Gorilla flush mount valve stems from JC Whitney. With these installed, you can flip them with no interference.
Old Feb 3, 2004 | 04:52 PM
KGodfrey's Avatar
Wow, That is excatly what I need. I did not know they made something like that. Good price too. Thanks for the info.
Old Feb 3, 2004 | 04:54 PM
Warrior453's Avatar
i think i got durablues on and if that isnt enought it has a cut out for the valve stem to make em even widee
Old Feb 3, 2004 | 04:55 PM
KGodfrey's Avatar
Question.....
On my 2001 Warrior will these Flush-Mount Valve Stems fit the hole already there or will it need drilling out?
Old Feb 3, 2004 | 04:56 PM
Colby's Avatar
Fit perfectly.
Old Feb 3, 2004 | 04:57 PM
KGodfrey's Avatar
Awesome...
Just finished placing an order... Thanks again
Old Feb 3, 2004 | 06:41 PM
Heapster's Avatar
I've run the flipped rims for years, and be really carefull not to hit bigger rocks or logs along the trail edge as with the +2 width you've gained, the wimpy 1/4" diameter tie rod ends are much more easily bent with the new longer leverage of the offset rim.
I've never bent a spindle off a jump, but have gone through 2-3 different tie rods and ends runing the flipped rims and banging it a little hard. At ~$35-40 a tie-rod end too, that aint cheap!
Old Feb 3, 2004 | 06:56 PM
trx250Rob's Avatar
Yeah, you will bent tie rods like crazy, put stress on the spindle (bearings) and pick up a bunch of bump steer. To each his own, but think this is major jerry rig, what you pick up in stablity you will lose in stiff handling with the handlebars getting ripped out of your hands everytime your tire hits a bump.
My advice to you is to try it for yourself, if your looking for better handling, this is not the way.
Old Feb 3, 2004 | 08:11 PM
Shav0's Avatar
if you cant get shorter ones, then just take the ones that are in there now, flip them around and put them in up-side down. Then just drill new holes on the other side. This way you can switch back and forth if you like.
