2002 warrior re-jetting
Old Feb 4, 2004 | 01:06 AM
ajc's Avatar
ajc
Default 2002 warrior re-jetting
looking to re-jet, yosh full system, k & n and airbox mod. need jetting tips & how 2's
Old Feb 4, 2004 | 08:07 AM
Crotts's Avatar
Are you using stock or dyno jets? I can tell you where i was at with a setup like that and dyno jets but stock jet # are different. Here is a site that I used for tuning my carb. It is for a different carb setup but it gives a good set by set tuning guide.
Old Feb 4, 2004 | 10:51 AM
ajc's Avatar
ajc
crotts,
i bought pro-design advantage kit, the same airbox cover as you, the kit comes with the dyno jets. k & n, aluminum adaptor & outerwear. i did not order the exhaust yet but was thinking about yosh system. i looked at the site you sent me to, i think that should help alot
thanx, ajc
Old Feb 4, 2004 | 02:40 PM
Crotts's Avatar
I was running a 150 main jet, stock needle in the center position and 3 1/4 turns on the mixture screw when I had just a pipe, K&N, and open lid. That will give you a idea where you'll be, start off rich and work your way down. Unless you get lucky you will get very good at taking your carb on and off, I have done it so many times now that it only takes a few minutes. I keep my stock needle in because I had trouble with getting the dyno needle set correctly, a lot of people do. The needle is designed for higher elevations.
Old Jun 1, 2004 | 08:51 PM
NLWarrior01's Avatar
Realizing this is an old post, but hoping for a response anyway .. the air/fuel mix screw .. when you turn it out do you get more fuel or more air?
I just rejetted tonight after putting in a uni filter (how is that supposed to mount in the warrior anyway?? does't have the same rigs as the stock, just the little foam peice on the end??) to a 150 main, never adjusted any other properties on the carb.
When the machine is idling it dies if I push the throttle WOT, when I'm just cruzing and punch it, the machine takes off great, when I hold it WOT it sputters. The plug doesn' t look wet when I take it out either, am I still lean? Machine seemed to be working better with the stock 145 jet in [img]i/expressions/face-icon-small-confused.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
byronman
Sep 6, 2015 06:34 PM
