how big of a tire will fit a 2000 600 grizz
how big of a tire will fit a 200 600 grizz
hi guys .
how big of a tire can you get on a 600 grizzly without any mods.
the yamaha dealer said that 28x12x12s and 28x10x12s might rub.
what do you think .my buddy dosant whant to buy the tires then find out thay rub.
and now he needs a lift kit.
he dosant want to lift it.
27" 589s will rub on a 660 Grizzly, I don't know about the 600 though. I had one once but never got beyond the stock tires with it. The 660 has more suspension travel than the 600 so the fact that 27" tires rub on the 660 doesn't mean they will on the 600. You'll need someone with 600 experience to respond. Also the wheels used will be a factor, if you use wheels (such as ITP C-Series) which space the tires out further (giving you a wider track) the tires will stick out past the fenders and are more susceptible to rubbing than if they were still inside the fenders (since the edge of the fenders curve down, or towards the tire)...
hi guys i just thought you might like to know that my buddy put the 28x12x12 and 28x10x12 mud lites on his 600 grizz and the only problem is the tyerod ends are rubbing on the in side of the tires so i spaced them out 1/8th inch and thay dont rub now.
and the wheel nuts are still all the way on the stud.
tank10rnk
08-10-2015 08:19 PM
