Cold Raptor...or what?????
Old Feb 5, 2004 | 11:29 PM
Too's Avatar
Too
Default Cold Raptor...or what?????
Took my 03 Raptor to KY this wknd.....pulled it out of the truck fired right up ......and thing would not hardly run...I would go to take off and bammmmm....it would die.... it did this several times...it had warmed up a little but are Raptors really this cold natured? I did not get a chance to ride..so i just pulled it into the Garage....first time its ever happened.....but i have usually let it idle for sometime before trying to take off..Thanks...[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 5, 2004 | 11:32 PM
Raptorboy4life's Avatar
Is the parking break on?
Old Feb 5, 2004 | 11:42 PM
Too's Avatar
Too
The parking break was off.....i know about the rev limiter while its applied..but thanks...
Old Feb 5, 2004 | 11:44 PM
DuneMe's Avatar
Have you checked your valve clearances? Probably not it but, good thing to check anyways.
Old Feb 5, 2004 | 11:46 PM
caliraptor's Avatar
My raptor wouldnt run that well when the weather changed. We went from 100F+ to 60-70s. I had to jet up and now the quad runs like a champ. Maybe elevation was higher as well? I went from 42ft below sea level to 4000ft and it wouldnt run as strong.
Old Feb 5, 2004 | 11:56 PM
Too's Avatar
Too
but what is strange it was running fine yesterday when i loaded it up....and tonight.... sorry...i was in Ky..and now IL....it running awful....it had zero power when i tried to take off...i had let it idle for a bit....
Old Feb 6, 2004 | 12:04 AM
Turtler's Avatar
I dont think its the weather. I ride my raptor in well over 100F down to near freezing and dont see a change in engine performance, start up ease or anything. Additionally, I ride in elevations from sea level to 7000 ft and do not have to rejet. I dont get noticeable drop offs in power with the elevation change.
Did you do a mod to your intake or exhaust without rejetting? Swap the plug and see if that helps.
Old Feb 6, 2004 | 12:54 AM
Outlawlawndragster's Avatar
After you let it idle " for a bit" did it run ok? Here in Idaho when it was around 20 I had to choke it keep choke on for a bit and back it off slowly then up my idle screw and let mine idle for a while . Then it was good to go
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
