Shock Resevoirs Necessary for MX?
Old Feb 9, 2004 | 05:55 PM
Magnum660's Avatar
Default Shock Resevoirs Necessary for MX
I'm buying +2 a-arms and new front shocks. I plan on racing mx, how important is it to have resevoirs? Do I really need them?
Old Feb 9, 2004 | 06:05 PM
horben's Avatar
Default Shock Resevoirs Necessary for MX?
They aren't necessary, but you may want them depending on your riding level. Reservoirs are used primarily for two purposes.
1. They allow the shock to say cooler by creating better separation from the gas/oil.
2. They allow the shock to be more adjustable.
a. Rebound adjustment.
b. Compression adjustment.
Of the 3 kinds of shock adjustments, only Pre-load is usually adjustable on the springs. Rebound and Compression are adjusted by controlling how fast and where the gas and oil are moved to during use.
The bottom line, if you don’t want to adjust your shock's Rebound and Compression characteristics then you’re find without reservoirs. However if you’re running 10 - 15 lap motos, then you better get the reservoirs too. (On many aftermarket shocks you can add the reservoirs onto the shock at a later time.)
-ben horgen
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
