HELP!!! YFZ problems.
Old Feb 17, 2004 | 02:31 AM
Carmelo15's Avatar
Default HELP!!! YFZ problems.
and ridley and have done what you told me to do. i checked the gasline for pinches or kinks and there were none. some people were saying to adjust your float? anyone know what that means or how to do it?
Old Feb 17, 2004 | 08:30 AM
Flynbryan's Avatar
You said you don't like to work on your stuff........ Did you install the Pipe, filter, and jet kit? If you had the stealership do it tell them what is happening, some of the ideas the guys from this site have given you and see what they come up with. If it is running improperly AFTER they did these mods, then it should be their baby, and THEIR responsibility to fix it. Just my .02. And adjusting your floats is adjusting the plastic floats in your carb bowls. Their like little plastic balloons attached to your fuel valve that regulates how much gas enters your carb. Without going into too much detail there is a way to adjust those valves so that you may change the amount of fuel that enters your carb before the floats shut off the supply. If your interested in a longer(better) explaination let me/us know. If your not gonna try to do it yourself though theres not alot of point in Me going into too much detail about it......
Customer Service #1
May 15, 2020 08:46 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
MrTrashMan2U
Sep 9, 2015 11:11 AM
Steeldon
Sep 8, 2015 10:51 AM
