warrior vs wolverine vs KFX 400 in the trails
Old 02-19-2004, 06:28 PM
2phast4u's Avatar
Default warrior vs wolverine vs KFX 400 in the trails
which will most likely win?
Old 02-19-2004, 07:18 PM
grizz76's Avatar
The Z/KFX unless you are talking mud, rocks and such that would require a 4x4 like the wolverine.
Old 12-14-2004, 03:03 PM
warriorbansheeboy's Avatar
good one, the warrior is the best in trail
Old 12-14-2004, 03:22 PM
ZillaRider87's Avatar
id have to give it to the Kawi/suki/cat 400's
Old 12-14-2004, 03:24 PM
VelociRaptor350's Avatar
depends on the rider, the 400 has an advantage.
7QuadSport7's Avatar
kfx 400 would definently win hands down
Old 12-14-2004, 03:42 PM
CTATV's Avatar
yeah im a warrior/wolverine fan but the my buddy has a Z400 and id give the win to them (of course same conditions same skilled rider). In the woods the Z just has such a broad powerband and the gears are so much longer then the warrior. unless its rocky or muddy which wolverine has the advnatage in ground clearance and traction.
Old 12-14-2004, 04:16 PM
95Wolverine's Avatar
It all depends on the trail and the conditions of it.
I've ridden with all types of quads.. and if the trail is loose by any means... ie sandy, wet leaves, just a little slick mud here and there, the wolverine will win.. why you may ask.. it has to do with traction.
In a tight corner, a wolverine will carve it's way around the corner with the back end tracking right along behind the pulling front wheels. The two wheel drive machines will try to push the front wheels that are trying to change direction.. then, if you get on the gas even the slightest bit early, the back end slides out.. if you slippin, yer not accelerating to the fullest capability.
In a twisty turny trail with lots of sand and corners, I've eaten raptors for lunch. Give 'em a short straight away and they are right back looking at the taillight, but in the tight stuff, the wolverine is rather suprising.
Old 12-14-2004, 09:42 PM
yeah but its soo much fun going around a corner sideways, then hooking up and pulling a wheelie out of the hole, snapping a few gears, then on to the next corner for more of the same. Thats how i get the ladies j/k
Old 12-14-2004, 10:01 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
Defenatly the KFZ, if there is no mud, snow etc, involved, the three are not comparable, sorry to say this but the warriors suspension compared to the KFX, is crappy.
Quick Reply: warrior vs wolverine vs KFX 400 in the trails
