What to buy first works fronts or rear shocks
Old Feb 20, 2004 | 04:07 PM
SkinnyBOi's Avatar
Default What to buy first works fronts or rear shocks
What should I buy first, front shocks or a rear shock. I got a quote of 300$ for the rear shock dual rate. It was also about the same for the front two. I bottom out all the time with little amounts of air. do ya think i can get away with new fronts and a stock rear???
Please help!!!
later,
skinnyBoi
Old Feb 20, 2004 | 04:32 PM
rescuediver's Avatar
I bought the rear works shock for my mojave, It made a world of difference in the handling and bottoming out. If you don't have serious problems coming from the front shocks and can't afford to buy both sets now, then I'd I suggests replacing the rear shock first.
Old Feb 20, 2004 | 04:54 PM
mojavekid13's Avatar
A blaster has a really good rear shock, For stock that is
So in that case i would go for the fronts
Old Feb 20, 2004 | 06:25 PM
SkinnyBOi's Avatar
Thanks for the reply's. Anyone else have anything to add?
Old Feb 21, 2004 | 12:55 AM
SkinnyBOi's Avatar
I really would like some input. thanx in advance
Old Feb 21, 2004 | 01:03 PM
Shav0's Avatar
Blaster shocks are JUNK. Your best bet is to find out what area you are having the most problems with and fix that first. If your front shocks aren't half as bad as the rear then do the rear one first. I find that the rear shock takes alot more abuse then the front so it might be a good idea to do that one first.
Old Feb 22, 2004 | 11:21 AM
I think Shavo said it pretty well! haha
the fronts would be the first thin i would change, the rears are bulit proff on those, for a stocker that is
txkevin
Sep 21, 2015 02:02 PM
bucklove007
Jun 8, 2015 07:28 PM
cornermike
May 27, 2015 10:04 PM
ragewraps
May 27, 2015 08:07 AM
250rCanCan
Sep 20, 1999 07:48 PM
