Best aftermarket axle for yfz
What is the strongest axle? I know the different companies, I just want one that will be least likely to bend. I jump big and want something that will take it if I dont land a jump just right. I like the fact that on some you can also switch the hubs to widen/narrow the width. Any info would be nice. thanks
Strongest axle in order:
RPM Dominator
Lonestar
Durablue
The lonestar is the best bang for the buck since you can buy those all day long for around $330 whereas the RPM is considerably more. Ask specific questions regarding the lifetime warranty each one has as well. I believe for instance with the RPM their lifetime warranty is good only for the original axle, if you break one and they send you a replacement I don't believe the replacement has a free replacement warranty like the original one did. Many people refer to the Durablue as Durabreak, I've never had one but apparently they don't seem to hold up as well as the other 2. And as far as switching hubs, on the Lonestar there are 2 spacers on each side which you add or remove to make your stance wider or narrower.
RPM Dominator
Lonestar
Durablue
Wow, that's a great price. I'm reading off my warranty card and it states "The Axcalibar Racing Axle is guaranteed not to bend or break for as long as you own it. This means if you bend or break your Axcalibar Racing Axle jumping or landing wrong, you are covered under this warranty." It doesn't get into specifics as far as if they replace it whether the replacement axle will also have a lifetime warranty, not sure about that. What I have found if you bend your axle, it's actually about as cheap to take it to a good shop that can straighten it, that ends up costing about the same as the shipping of the axle to Lonestar. In other words, only use your lifetime warranty if you break it.
