SOMEONE PLEASE HELP
Old Feb 24, 2004 | 10:51 AM
mojavekid13's Avatar
Default SOMEONE PLEASE HELP
Ok I need this question answered for me fast
Say i have 22' tires, and go to a 20' rear tire, Does the give me More Bottom end Or top speed??
Old Feb 24, 2004 | 10:59 AM
Come on guys, Need you to settle this for me
Old Feb 24, 2004 | 11:02 AM
FastbansheeandKodiak's Avatar
I belive the smaller tire will give you more bottem end and you will lose top end but i may be wrong.
Old Feb 24, 2004 | 11:06 AM
NLWarrior01's Avatar
That's correct.
Putting on a smaller back tire reduces your top speed but increases your acceleration. Same net effect of going to a smaller front sprocket or larger back sprocket.
Old Feb 24, 2004 | 03:03 PM
ATVBos's Avatar
need ne one answer a question like that common sence, but any way i put it this way the biger the tire the lager the circumference right. so if you go 1 rvolution you cover that much ground. so if you put a smaller tire on you will cover less groung per revolution. less speed at same rpm, so more bottom end. the best way to think about this would be to totaly over exadurate it really huge tire and really small tire, that makes it easy to comprehend
