thanks
Old Feb 24, 2004 | 03:35 PM
saaben's Avatar
Default thanks
i just wanted to thank everyone for letting me spend some time on this site and learn about the atvs. i purchased a 1985 kodiak 400 4x4. it is in great shape with 700 miles.has winch good tires and had a service on it. paid 2250.. i do have a ?. how much air presure do you run in the tires. and where can i get a gauge that shows psi that low ? i guess one other ? would be any advise on best place to get an ownwers manual. thanks again for the education.
Old Feb 24, 2004 | 03:47 PM
nubbin's Avatar
Default thanks
My tires call for 3 1/2 psi front and back. I run 5 psi in front tires and 6 psi in back tires. It makes for easier steering and I have been told that it is better protection against flats. You should be able to pick up a gauge at any dealer. lol
Old Feb 24, 2004 | 05:09 PM
YAMHY's Avatar
Default thanks
I have an '03 Kodiak 400 4x4 and my manual says to fill to 4 psi front and rear. Although on this one I go with nubbin and usually fill up to 5 psi on both of them.
Glad that you like your new ATV
Old Feb 25, 2004 | 05:26 PM
nubbin's Avatar
Default thanks
Hi saaben, it's me again. My dealer recommended 5 lbs both front and back, but I ride double with my wife most of the time so I put a extra pound in the back because of the extra weight. I hope this helps. lol
Old Feb 25, 2004 | 05:27 PM
Punker660's Avatar
Default thanks
Check the little tool kit for the low pressure tire gauge if you have one.
Old Feb 26, 2004 | 09:10 PM
farmerboy's Avatar
Default thanks
on my sportsman the manual says to put 7psi in the front and back which is what i do. so i think u should put what the pressure on the sidewall of the tire says because the manufaturer knows how much u should put in.
'04 polaris sporstman 400
RIDE A POLARIS!!!!!!
