Changing Raptor Oil Questions
Old 02-25-2004, 07:14 PM
Punker660's Avatar
Default Changing Raptor Oil Questions
It just sits on top. You don't screw it in.
Old 02-25-2004, 07:19 PM
PinkRaptor's Avatar
I never have to change my oil.
Old 02-25-2004, 07:21 PM
garyc660R's Avatar
Correct. Add appropriate amount of oil and let it run a minute or 2. Then, let it sit a couple of minutes and check for proper oil level.
Old 02-25-2004, 09:13 PM
KILLERCUDA's Avatar
Thanks Guys,Now is that drain plug the one below the front sprocket? If it is man that seems like an awkward place for a drain plug. I'm used to the ol' Warrior where the drain plug was on the bottom of the motor.
  #15
Old 02-25-2004, 09:16 PM
Punker660's Avatar
Yes, 17mm bolt.
  #16
Old 02-25-2004, 09:28 PM
XxDumontRaptorxX's Avatar
I used kendal straight 30w
  #17
Old 02-25-2004, 09:38 PM
KILLERCUDA's Avatar
Thanks,Again
  #18
Old 02-26-2004, 08:57 PM
KILLERCUDA's Avatar
Hey Guys, Got the motor drained(so I thought) opened the oil resivor wiped it off and seen the oil was still touching the dip stick? Whats up with that? Are you suppose to take the dip stick off when u drain the oil so it gets the flow? Thanks.
  #19
Old 02-26-2004, 09:07 PM
Punker660's Avatar
Yes.
  #20
Old 02-26-2004, 09:24 PM
pusboil's Avatar
You can download the Raptor owners maual from the net gives all info but here is the break down straight from the manaul
CHANGING THE ENGINE OIL
1.Remove:
 Engine skid plate
2.Start the engine and let it warm up for several
minutes.
3.Stop the engine and place a container under
the engine oil drain bolt.
34.Remove:
 Dipstick 1
 Engine oil drain bolt (oil tank) 2
 Engine oil drain bolt (crankcase) 3
Drain the engine oil from the oil tank and
crankcase.
5.If the oil filter cartridge is also to be replaced,
perform the following procedure.
Replacement steps:
Remove the oil filter cartridge 1 with an oil
filter wrench 2.
Apply a thin coat of engine oil to the O-ring
3 of the new oil filter cartridge.
CAUTION:
Make sure that the O-ring 3 is properly
seated in the groove of the oil filter cartridge.
Oil filter wrench:
P/N. YM-01469, 90890-01469
3 - 22
CHK
ADJ CHANGING THE ENGINE OIL
Tighten the new oil filter cartridge to specification
with an oil filter wrench.
6.Install:
7.Fill:
 Oil tank
(with the specified amount of the recommended
engine oil)
NOTE:
 Pour the engine oil in several stages.
 First, pour in 1.75 L (1.54 Imp qt, 1.85 US qt)
of oil, and then start the engine and rev it 3 to
5 times. Stop the engine, and then pour in
the remainder of the specified amount.
CAUTION:
When starting the engine make sure the
dipstick is securely fitted into the oil tank.
8.Install:
 Dipstick
9.Warm up the engine for a few minutes, then
stop the engine.
10.Check:
 Engine
(for engine oil leaks)
Quick Reply: Changing Raptor Oil Questions
