Lean due to temp??????????
Old Feb 26, 2004 | 07:01 PM
Too's Avatar
Too
Default Lean due to temp??????????
03 raptor, rode it for about an hr and then WOT run...and plug was white...it was about 40degrees out...I have full yosh. and k&n filter and jet kit installed...and 2 1 1/2 holes in filter lid...I took it back to the dealer and he said it could be caused by temp...the did the jetting...there are no sympthoms of lean beside plug..no backfiring, dieing on topend nothing...im lost...pls help....
Old Feb 26, 2004 | 07:08 PM
warrior68man's Avatar
possibly could be caused by temperature.....but i dunno if 40degrees would make much of a difference.
Old Feb 26, 2004 | 11:19 PM
Hayseed's Avatar
Did you find out where your jetting was at after you asked this question yesterday? BTW, a white plug doesn't necessarily mean you're lean.
Old Feb 26, 2004 | 11:52 PM
RoostItUp's Avatar
Temp does effect jetting alot but generally the air/fuel mixture leans out when it gets warmer. If it's not acting like it's lean then it's not, just leave it how it is. If the bike is stock and something goes wrong because of that it's Yamaha's fault and they should cover that under warranty.
Old Feb 26, 2004 | 11:59 PM
BigScary's Avatar
it would lean out when it is colder I believe
Old Feb 27, 2004 | 01:25 AM
RoostItUp's Avatar
my bad...
Old Feb 27, 2004 | 09:33 AM
Too's Avatar
Too
Hey guys thanks alot...Haysee, as far as the jet size that came with my Yosh. full system and k&n filter and jetkit, im not forsure....i guess i should start learning these things..but if you guys think it is ok...i trust you guys....Like i said it does not back fire or fall off on top end.....when i do shut the motor off you hear a little puff or almost like a small back fire....thanks guys
Old Feb 27, 2004 | 11:20 AM
X7734X's Avatar
What octane of gas are you running?
Old Feb 27, 2004 | 12:21 PM
Too's Avatar
Too
im actually running a combination of 87 and 92.....
Old Feb 27, 2004 | 12:29 PM
Chilly's Avatar
If the plug is white, then it is definitely lean... if it were mine I'd richen it just a bit, cooler weather will have that effect, but usually it takes quite an extreme to make a visible difference. I like to run on the rich side of perfect, you get better cooling of valves, piston, etc that way.
shimanok2
Jan 29, 2016 07:37 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Halffast17
Sep 11, 2015 02:30 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
