need info. on a banshee
Old Mar 2, 2004 | 08:50 PM
biggerandfaster's Avatar
Default need info. on a banshee
i have a 98 banshee, i just got some portworks done to it.when the bike is idling only 1 cylinder is firing but when you ride it both fire what could cause this,need info. please
Old Mar 2, 2004 | 09:07 PM
HiFlyinRaptorRyder's Avatar
It sounds like something in the carb is sticking until you give it gas. Take the carb apart and clean it good and inspect to make sure there is nothing wrong with it. It doesnt sound like an air leak, but take starter fluid and spray it around the intake boots, if the idle raises or lowers you have an air leak, but I highly doubt thats what it is.
Old Mar 2, 2004 | 09:21 PM
also when im idling every once in a while it will pop on the one cylinder. also when it ilding one side is blowing out hot air while the other is blowing out cold air unilt you ride it then it's hot air
Old Mar 2, 2004 | 11:33 PM
JohnnySplat's Avatar
the hot and cold thing is over my head, but the popping sound is something i MIGHT know about. i dont know for sure, but mine does the same thing and i think it happens when you're burning too much oil, mine does it when i start up without shaking the bike to help remix the oil and gas in the tank that has separated, because the oil will sink and your gas will be too rich until you shake it up while riding. if i shake the bike around and mix it back up, its ok and i dont have that problem. try that and see if it makes a difference.
Old Mar 3, 2004 | 01:11 PM
AlkyBurninX's Avatar
Carbs are out of sync or the pilot jet is clogged.
Old Mar 3, 2004 | 04:09 PM
Hiram's Avatar
My thoughts exactly,
and the cold air thing is from the cylinder not firing and just cycling throw the stroke with the help of the cylinder that is firing.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
panicmanic
Aug 3, 2015 10:49 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
