need help
Old Mar 4, 2004 | 02:04 AM
Baiter's Avatar
Default need help
i orderd a tag bar kit for my 04 rappy nd need some help i want to get ride of thi key but u cant just unplugh it like some one said. what i want to know is con i put a thether on and wire it in to what use to be the key. also i need to know what kind of wiring a thether has 2 wire or 3?
Old Mar 4, 2004 | 04:29 AM
XxDumontRaptorxX's Avatar
Default need help
Or maybe you can hook them up to "think the key is on" when you turn on the run switch, and "think the key is off" when the off switch is off. You would have to do a bit of wiring and modding, just an idea though. I don't know if you bypass(sp) the key if it drains batery or not. I think this was brought up not too long ago, so don't look for too much help on the public forums, as this information could be used to steal quads. Maybe someone will grace you with a pm. I hope they know you wont be. As for the wiring, I don't know.
Old Mar 4, 2004 | 05:22 AM
Baiter's Avatar
Default need help
i tryed to by pass it it works but drain s the batt even when the killis off ineed to know if i can use ma thether like te ones on sleds but ialso need to know what kind of wiring you need to hook up athether regularly that will probly answer my ?
