Banshee Troubles
Old Sep 3, 1999 | 03:30 PM
Harold's Avatar
Too rich on one cylinder, could it be the wrong size jet???was this carb. on the cylinder that went bad????hmnnn????$$$$
Old Sep 3, 1999 | 05:05 PM
ynotatv's Avatar
samson, have them check the carb. slides it sounds as though they might have swapped them. meaning they put the right one in the left carb. there is a small difference in the choke side (left). i had this happen to me and it ran real rough and blew gas out the pipes.
Old Sep 3, 1999 | 08:15 PM
SaMs0nOLD's Avatar
Yes it was the slides that where switched and causing the problem. I guess the first shop made this mistake when putting the carbs back together.
All I can say is the Banshee runs awsome now with the LRD pipes and silencers. I just ordered Boyesen rad valves to up the performance even more.
Also I just recieved CT's TCS shocks today, and will install them tommorow. I'll let you know how they work out.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
