Bent raptor pitman arm
Old Mar 6, 2004 | 01:17 AM
JayBird04's Avatar
Default Bent raptor pitman arm
It seems like I bent my pitman arm (the piece of metal that connects the steering stem to the tie-rods) on the raptor. I guess all those trees are bad for the front end. I was wondering if anyone else has ever done this and what they did to fix it? I noticed some old posts about this, but nobody ever responded. I was thinking about trying to bend it back since I can't seem to find any on ebay. I really don't want to go to the stealership and get robbed again. I already had to buy a new spark plug cap from them for $26. Is there any thing aftermarket that I can get, like a steering stem that comes with one or something? Thanks.
Old Mar 6, 2004 | 01:48 AM
RaptorRacer1's Avatar
Houser racing has been advertising in the ATV magazines recently that makes replacement ones and also ones with adjustable steering travel. $40 for standard or $75 for adjustable. I don't know how much a stock Yamaha one is. I bent mine and the shop fixed it for me. They put it in a vise, heated it with a torch till it was glowing and then bent it back straight. It has held up for almost 2 years now. It is just cast iron, I believe, so this should not hurt its durability. Good Luck
RR1
Old Mar 6, 2004 | 07:30 AM
caliraptor's Avatar
Ive got a pitman arm....brand new, just laying around [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 6, 2004 | 10:13 AM
warrior007's Avatar
I bent mine before. Seems like the tie rod end should bend first, the pitman is a honkin piece of metal.
Old Mar 6, 2004 | 10:54 AM
JayBird04's Avatar
Thanks for the replies. RR1, where could I get some prices for those pitman arms by houser? I am not sure if I would be able to bend it back the right amount or not. So I figure I mind as well get a new one.
Old Mar 7, 2004 | 03:19 PM
Try Houser's website. They have them listed for $40 for the non-adjustable ones. Google "Houser ATV Racing" or give 'em a call at
1-877-6-GOFAST
Also check the April edition of Dirt Wheels, page 222 for the ad. Good luck.
RR1
Old Mar 9, 2004 | 12:45 AM
JayBird04's Avatar
I will be sure to check out their site. Thanks again for the info.
Old Feb 22, 2005 | 06:45 PM
DK1977's Avatar
How do you remove the ball joints from the pitman arm? They seem to be stuck.
thanks,
DAle
Old Feb 22, 2005 | 07:00 PM
rutelis's Avatar
i bent mine too...i bent my tie rode and the pitman...i replaces my tie rod and i had play in my handelbars so i got a new pitman and i still have play in my steering...i think it might be my bushings or my stearing collem.....ne idea what would cause this?
Old Feb 23, 2005 | 11:56 AM
warrior007's Avatar
Tighten the nut on the bottom of the pitman. It sounds loose. use locktite.
