Roll Design Shifters? Any Good?
I dont have the roll shifter but i have a prodesign and i am not really sure if i like it yet or not. Have any of u guys noticed that the distance u have to move the shifter is significantly more than with the stock setup. Ive noticed im missing up shifts alot with the new shifter. Is anybody else having this problem and how did u fix it if u did.
The Roll Design does eliminate the linkage, I have one and it's alot nicer than the OEM or aluminum aftermarket shifters. The throw is a bit longer but definitely more positive. The RD is probably the most expensive of the aftermarket shifters though. If you dont care about the look there are cheaper ones to go with but I dont regret the RD myself.
Originally posted by: Ugintel
Do the rolldesign shifters get rid of the linkage?
yes it does
removes the linkage and the mechanical advantage the linkage provides
you will have to throw the shifter a little further,,,but it is a much better feel when shifting (after you get used to it)
